how do you configure two counters for a single task?
Hello Everyone,
I would like to know how to configure two counters for a single task. At first, I have put two start task for two counters and it did not work. Now, I have put Control Task to control the task of the other counter. Appreantly, all what it does is that it makes one counter work while other is stopped or not working. I have attached a picture of the VI below.
Thanks.
Mechanical Engineer
(3,018 Views)
Hi Marwan,
I'm not sure of what you want to do with the two tasks, do you want to synchronize both counters with one trigger?
Miguel Fonseca
Applications Engineer
http://www.ni.com/support
(2,985 Views)
What do you mean by "...two counters for a single task?"
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(2,977 Views)
Sorry for any confusion but what I meant is that I want both counters to gather data in the same time. When I put to "Start task" in the VI, it gives me an error saying that you must reserve one of them but when I do that, it makes one counter working but the other on-hold.
Hope this helps,
Please inform me if you need further explanation.
Mechanical Engineer
(2,967 Views)
I'd like to know which card (PCI-PXI-USB) are working with? If the lines for the counters are multiplexed, there is no way to acquire data at the same time.
I case the lines aren't multiplexed ten you can use this example to synchronize Two Counters using a Dummy AI and an Arm Start Trigger.
Miguel Fonseca
(2,957 Views)
Hello Mike,
We are currently using NI-cDAQ 9191 chassis with NI 9401 Digital I/O module that can use counters. I don't know if the lines for the counters are multiplexed or not. I have attached the VI for you to look at it.
Thank you for your effort.
Mechanical Engineer
(2,938 Views)
