how do you place a picture in another picture
Accepted by Jim12345678
Yes.  There is a function to do what you want.
Convert a big picture to array takes time.
George Zou
Message 11 of 21
(1,562 Views)
Here's probably all you really need (currently using fixed H position, but that can easily be changed, of course):
Message 12 of 21
(1,552 Views)
Thank you.  This does all the array conversions for me and is a much simpler implementation.
Message 13 of 21
(1,538 Views)
This is so cool! This should be one of the best answers. Come on Jim1234!
Message 14 of 21
(1,528 Views)
What are the names of the four blocks you are using there? I want to find them.
Message 15 of 21
(1,527 Views)
For a picture like this (with dotted line, LabVIEW version#, ...) :
https://forums.ni.com/t5/LabVIEW/how-do-you-place-a-picture-in-another-picture/m-p/4246798?lightbox-...
you can simply download the image, and drag & drop on a diagram.
It will be converted to diagram automatically.
The diagram is embedded inside the image.
George Zou
Message 16 of 21
(1,516 Views)
Thanks for sharing this info, George!. I always wonder why people post pictures instead of attaching a block diagram.
Message 17 of 21
(1,506 Views)
I typically show a picture AND attach a VI (see here). Good enough? 😄
While snippets are OK for very (very!) simple code, they lose a lot of metadata compared to the actual VI (e.g. settings, connector pane assignment, etc.).
Note that George's code still does the expensive dance from picture data to 2D array and immediately back to picture data. Flatten/unflatten an image just to change a few scalar cluster elements is obviously not needed and my code bypasses it completely. Definitely more efficient! Have you tried?
Message 18 of 21
(1,497 Views)
Yes. if both images are constant, you can do the convert before enter the loop.
George Zou
Message 19 of 21
(1,483 Views)
My point was that you can operate on the pink cluster to adjust the position. No need to do the detour over the blue 2D array (inside or outside the loop) 😄
Message 20 of 21
(1,473 Views)
