how do you use labjack with labview?
Have you contacted their tech support, I have found them responsive.  I have not compiled labjack code, but in the dev environment in LabVIEW 2009, it has worked.  We had to recompile the VIs supplied by LabJack which was a bit of an effort as I did not have pre-2009 on my machine.  But they called me within a day.
-p
Paul
Message 11 of 18
(2,700 Views)
Thanks, I posted on their website also. I am thinking it is primarily a Labview/Xcode (mac os) issue. Where the labview project file (and generated .lsb) doesn't allow it to access the USB or something silly like that.
As I said in the previous post, the code works great in C. But any hardware calls made in C seem to not happen when inside the labview project file. Ideally the program I'd laike to make would launch a C program in the background to fetch/send data from the hardware, and the labview would be there just to control/interpret the data.
Message 12 of 18
(2,685 Views)
I am using labjack U in labview 8.0. I am having the problem that vi's of labjack are not there. I want to show my sensor's output which is change in resistance in analogue form on computer screen. Actually I want to plot a graph of resistance versus time using labjack on labview. Can you help me in this?
Message 13 of 18
(2,141 Views)
I am using labjack U in labview 8.0. I am having the problem that VI's of labjack are not there. I want to show my sensor's output which is change in resistance in analogue form on computer screen. Actually I want to plot a graph of resistance versus time using labjack on labview. Can you help me in this?
Message 14 of 18
(2,138 Views)
Not sure which device you have, but start with the following links:
U12:  http://labjack.com/support/u12/examples/labview
UD (U3, U6, UE9):  http://labjack.com/support/ud/examples/labview
LJM (T7):  http://labjack.com/support/ljm/examples/labview
Message 15 of 18
(2,131 Views)
How do I get LabView to recognize Labjack T7 series? What are the procedures involved?
Message 16 of 18
(254 Views)
Did you try to follow what is described in the link just before your message?
Rolf Kalbermatter  My Blog
Message 17 of 18
(239 Views)
Yes indeed.  Start with the 7 steps in the Getting Started section.
https://support.labjack.com/docs/labview-for-ljm-windows-macos
Message 18 of 18
(209 Views)
