11-23-2009 06:09 AM
Have you contacted their tech support, I have found them responsive. I have not compiled labjack code, but in the dev environment in LabVIEW 2009, it has worked. We had to recompile the VIs supplied by LabJack which was a bit of an effort as I did not have pre-2009 on my machine. But they called me within a day.
-p
11-23-2009 01:35 PM
Thanks, I posted on their website also. I am thinking it is primarily a Labview/Xcode (mac os) issue. Where the labview project file (and generated .lsb) doesn't allow it to access the USB or something silly like that.
As I said in the previous post, the code works great in C. But any hardware calls made in C seem to not happen when inside the labview project file. Ideally the program I'd laike to make would launch a C program in the background to fetch/send data from the hardware, and the labview would be there just to control/interpret the data.
11-06-2013 02:00 AM
I am using labjack U in labview 8.0. I am having the problem that vi's of labjack are not there. I want to show my sensor's output which is change in resistance in analogue form on computer screen. Actually I want to plot a graph of resistance versus time using labjack on labview. Can you help me in this?
11-06-2013 02:02 AM
I am using labjack U in labview 8.0. I am having the problem that VI's of labjack are not there. I want to show my sensor's output which is change in resistance in analogue form on computer screen. Actually I want to plot a graph of resistance versus time using labjack on labview. Can you help me in this?
11-06-2013 09:01 AM
Not sure which device you have, but start with the following links:
U12: http://labjack.com/support/u12/examples/labview
UD (U3, U6, UE9): http://labjack.com/support/ud/examples/labview
LJM (T7): http://labjack.com/support/ljm/examples/labview
08-28-2025 05:38 PM
How do I get LabView to recognize Labjack T7 series? What are the procedures involved?
08-29-2025 01:20 AM
Did you try to follow what is described in the link just before your message?
08-29-2025 04:07 PM
Yes indeed. Start with the 7 steps in the Getting Started section.
https://support.labjack.com/docs/labview-for-ljm-windows-macos
