Hi John,
Thanks for the information. Unfortunately, when I did a search of transparent
in the Developers Exchange, your information could not be found. Would you be
kind enough to locate it and let us know where it is?
Thanks in advance,
On Wed, 28 Feb 2001 16:12:51 -0800 (PST), John Lum wrote:
>If your difficulty is that the transparency is lost when you get your
>graphic into LabVIEW, you might need to work a little harder to get an
>appropriate image or image format.
>I posted an answer with additional info to a similar question some
>months ago--do a search for "transparent" in the Developer Exchange at
>ni.com and it should be the first hit.
>Regards,
>John Lum
>National Instruments
SolidWorks Research Partner National Instruments Alliance Member
Christopher Dubea Phone: (504) 847-2280
Vice President of Engineering Fax: (504) 847-2282
Moving Parts L.L.C. email: cdubea@movingpart.com
P. O. Box 6117 URL: http://www.movingpart.com
Slidell, LA 70469-6117
