how i can send measurment reading to excel sheet?
q.1: i have some readings and i want to send them to excel sheet
q.2: how i can draw a gragh for these readings?
Message 1 of 12
(3,593 Views)
You can use a "write to spread sheet" to log the data and "read from spreadsheet" to read the data from the stored file.
Message 2 of 12
(3,590 Views)
Can you explain the dataformat and dimensions?
Message Edited by muks on 01-19-2010 12:55 PM
Message 3 of 12
(3,589 Views)
see the attachment
i want to draw a graph form the last results of the readings
Message 4 of 12
(3,577 Views)
Can you attach a screen shot as i am having only 8.0?
Message 5 of 12
(3,574 Views)
i have a lot of readings , i can't send them by your way.
Message 6 of 12
(3,573 Views)
Message 7 of 12
(3,568 Views)
What are you trying to do!!!!!!
Why are you using these many case structures and you are checking the condition from one source.Can you explain a bit?
Message Edited by muks on 01-19-2010 02:03 PM
Message 8 of 12
(3,566 Views)
i want to record the varying on the tempreature during two hours , and i did maually that be arrising the degrees randolmlly,
that's not our case
all what i care about how i can but the result in excel sheet and draw a graph from this result .
Message 9 of 12
(3,548 Views)
You can do this directly like this right?
Message 10 of 12
(3,540 Views)
