how not to omit leading binary zeros with format into string
I'm using format into string to format serial data .  The problem I'm having is that Format into String with "%b" format identifier omits leading zeros
in the string..   ie...  "3" becomes "11" when I need it as "0011"
(3,776 Views)
Add a zero to your format string. In other words, %04b tells it to pad with zeros up to 4 places. This is documented in the LabVIEW Help.
(3,772 Views)
Just tried that... it didn't work.
(3,768 Views)
Accepted by topic author lastcall18
see figure:
(3,758 Views)
