xy graph in excel using activeX
Hi
I am trying to plot a XY graph in excel using Active X. I have two coloums of data one should be X the other should be Y. I am using XlXYscattersmooth graph type and giving the range as A1 to B5. But when the excel plots it, I am getting two series rather of X data points rather than XY. I know I am doing a simple mistake in choosing some variable but I am not able to figure out where I am going wrong.
Can anybody please look at my code and correct the code in order to get a XY plot rather than getting two different series.
Thanking you in advance
Nitin
(3,303 Views)
hi,
in your code
Set Cell Value with Range.vi is missing. attach that vi also.
<<Kudos are welcome>>
(3,289 Views)
Hello
Here is that Set Cell Value with Range.vi
Nitin
(3,272 Views)
