how register events for hovering over an array
cool!
Altenbach : i was thinking i could not use your proposition from the table reading, because there you have directly from property nodes the bounds of the elements. i did not tought of doing it like Marc shows, simply use the "bounds" properties!
Thanks enormously guys. it works like a charm.
will look at your tictactoes now...Smiley Happy
... And here's where I keep assorted lengths of wires...
Message 11 of 14
(682 Views)
Also notice that the array in my TTT player is actually an indicator and thus can only be modified by the code according to the clicks and not directly. This can be useful in some cases. 🙂
The mouse down event does not care if we are dealing with a control or indicator.
Message 12 of 14
(674 Views)
Christian, I think you mean "lose" in your tic-tac-toe program, not "loose." Just trying to help Smiley Wink
Message 13 of 14
(673 Views)
'told you there are bugs! 😉
I am much more visual than verbal, that's why I suck at text based code. 😮
Message Edited by altenbach on 05-11-2007 01:54 PM
Message 14 of 14
(671 Views)
