how the compiled labview communication bit file the usrp rio be reading and using by labview 2015
please for all ,tell me how can i using the bit file by the labview 2015 that have been made before by labview communication and that compiled on the usrp rio
(2,887 Views)
Accepted by foge
Hello foge!
From what I can understand, you would like to use a bitfile created in LabVIEW Comms in LabVIEW 2015.
I found a KnowledgeBase article that should answer your question!  In short, you can use a bitfile created in LabVIEW Comms in LabVIEW 2013 or newer!  This is true if the bitfile foes not include complex types for controls or indicators.
I hope this helps!
Casey L.
Applications Engineer
(2,775 Views)
thank you for your answer and  I need to know how can I use the VIs and subVIs  to draw the block diagram of the labview 2015 that enable me to read the bitfile from usrp rio
@levitt2me wrote:
Hello foge!
I hope this helps!
Casey L.
(2,766 Views)
Hello foge!
It would likely be best to create a new thread, as this is a separate question.  But, here is some helpful documentation on opening a reference to a bitfile!
Open FPGA VI Reference Function
Opening a Reference to a Bitfile
Best,
Casey L.
(2,751 Views)
