how to Synchronize PCI4472 and PCI6023E
I want to sysnchronize one PCI 4471 and one PCI6023E using RTSI cable. Any example program??
(2,644 Views)
You can only synchronize a DSA device and E Series device when using the PXI-backplane. The problem with trying to sychronize the DSA and MIO in the PCI form factor is that the PCI DSA boards use a special RTSI line that the E Seris counters cannot recognize.
Todd D.
(2,644 Views)
The KnowledgeBase linked below is an excellent reference for which NI Hardware can be synchronized with a DSA device, including some special methods to use. Depending on which DSA device you use, it is possible to synchronize a PCI DSA device with a PCI E Series device. Please see the link below for more information:
Can I Synchronize a DSA Device with Other NI Hardware?
Sonya Wornson
Applications Engineer
(2,644 Views)
