how to access SQL server using SQL toolkit from LabVIEW
I 'm using Labview SQL toolkit to read from data base
it is Okay for dBase but for SQL server we couldn't
as we could read only the numeric fields but no longer for character fields
(3,032 Views)
Check to see if the text fields are defined as nvarchar or nchar. If I remember right, the old toolkit had some problems with these data types.
(3,031 Views)
