Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
how to access SQL server using SQL toolkit from LabVIEW
naser
Member
03-21-2002
05:29 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I 'm using Labview SQL toolkit to read from data base
it is Okay for dBase but for SQL server we couldn't
as we could read only the numeric fields but no longer for character fields
0
Kudos
Message
1
of 2
(2,983 Views)
Reply
Re: how to access SQL server using SQL toolkit from LabVIEW
Dennis_Knutson
Knight of NI
03-21-2002
10:22 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Check to see if the text fields are defined as nvarchar or nchar. If I remember right, the old toolkit had some problems with these data types.
0
Kudos
Message
2
of 2
(2,982 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
