01-15-2006 10:10 PM
01-16-2006 03:09 AM
Tools>>Advanced>>Edit Palette Views.
Go into the user libraries palette and right click>>Add Submenu>>Link to a library. Then select the DDE LLB (at vi.lib\platform). You should now have them as a subpalette inside the user libraries palette.
It is possible to include the VIs elsewhere, but that's more complicated. You can try searching this board for "readonly.txt" to find out how.
