how to add DDE VIs to Function palette
There isn't the DDE VIs in function palette, how to add it, Thanks
(2,997 Views)
Tools>>Advanced>>Edit Palette Views.
Go into the user libraries palette and right click>>Add Submenu>>Link to a library. Then select the DDE LLB (at vi.lib\platform). You should now have them as a subpalette inside the user libraries palette.
It is possible to include the VIs elsewhere, but that's more complicated. You can try searching this board for "readonly.txt" to find out how.
___________________
Try to take over the world!
(2,990 Views)
