how to add rows in the multicolumn listbox
hello muks,
thanks a lot. the key issue is how to add the second row, third row by click-button without covering.
Message 11 of 18
(3,074 Views)
Accepted by WGQ
Can you try that. I will post a screen shot but now that you know how to handle data in mult colmn box you can try to add the rows right? We will correct it if you are stuck but start trying...
Message 12 of 18
(3,073 Views)
without covering.
What do u mean by "covering"?
Message 13 of 18
(3,071 Views)
hello muks,
thanks a lot. I just try and it seems that the function is implemented.
I just attached an example VI for your information. do you know how to show the latest rows in the message window?
Message 14 of 18
(3,044 Views)
since Muks has given you out lots of examples and tips and things like that why dont you try out this one on your own?
Regards
Guru (CLA)
Message 15 of 18
(3,039 Views)
WGQ wrote:
hello muks,
I am still stuck with 8.0 so can you post a screen shot instead?
Message 16 of 18
(3,034 Views)
Hello muks,
please see the attached pictures.
Message 17 of 18
(3,030 Views)
hello Guruthilak,
thanks for your advice, just now I tried to modify the VI and realized the functions of highlighting the active row and scrolling automatically the vertical scrollbar to the (last) active position.
Are there any optimized methods?
thanks in advance.
WGQ
Message 18 of 18
(3,021 Views)
