how to add string elements to an array?
I want to add string elements to an array by typing them in-for example if I type in "blue" first and it adds the first element, then I type in "red" and then array is "blue, red", etc. Thanks in advance
(3,861 Views)
Build array, and possibly Array to Spreadsheet string, should solve this (depending on if you want to watch it as an array of a comma separated text as you wrote).
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,842 Views)
Just to give you the basic idea:
You'd probably want to add some sort of input validation, check for an empty string, etc.
Andy
(3,840 Views)
