how to be able to read by graph chart if line 0-3 is a 1 or 0?
I have this program which writes a 1 or 0 to a physical board but now i am wondering how can the graph chart read if the Elvis is sending a one or zero? I am trying to display the signal from each lines. Thank yoU! 😃
(2,920 Views)
Hi txrxmo,
I have this program which writes...
Which program? Any VIs to attach?
- Do you use a graph or a chart? There's a difference between...
- Graph/charts are indicators, they only display data instead of "reading" them
- To display data on a graph/chart you have to wire them to their terminal
(2,913 Views)
I am currently using a chart. so i am trying to display the lines 20-23 but it still keep on displaying one waveform.
(2,896 Views)
Hi txrxmo,
why don't you follow the context help of the chart? It explains pretty clear how to plot more than one plot in the chart!
Also read the LabVIEW help. There are even examples showing how to achieve your goal...
For a chart you either have to wire a 2D array or a 1D-array of waveforms to plot more than one signal!
(2,886 Views)
Hi GerdW!
Thanks so much for the help, i manage to solve the problem using Index Array. 😃
(2,867 Views)
