how to build a CMOS/TTL to RS232 convertor with Labview7.0
my GPS receiver provider a serial CMOS/TTL commnication port and I have a PCI-6014 DAQ card. How to program UART in abview7.0 to convert CMOS/TTL siganal to RS232 protocol signal by using PCI-6014 DAQ.
(3,576 Views)
Why can't you plug your GPS on the RS232 port and read il with LabVIEW ?
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(3,576 Views)
To use the RS232 Port he might need a circuit to shift (and mostly invert) the TTL level to RS232 levels.
traditional solution is a maxim IC that does the job.
shematics can be googled 'TTL RS232'
Even if he buy a ready device that will be cheaper than the DIO solution 😉
Greetings from Germany
Henrik
LV since v3.1
(3,576 Views)
Yes, probably it will be a good idea to convert the data from the TTL port of your GPS receiver to RS 232 signal (pass the signal through a RS 232 driver). You can then use LabVIEW to read it directly.
What are you using PCI-6014 exactly for?
Good luck !
(3,576 Views)
A simple way is to use a chip hardware convertor. But it is possible to program a UART protocol driver with labview. I'm very appreciated if someone can provide the driver code or some advice for the driver programming.
(3,576 Views)
I just use PCI-6014 for GPS CMOS/TTL signal acquisition
(3,576 Views)
Can you explain your ideal in details.
GPS send serial singals with CMOS/TTL level which can not be accepted by RS232. So I want to read it through DIO of PCI-6014 and process these signal using labview.
I need extract real data from these signals.
In this project, we need this software driver instead of hardware convertor from TTL to RS232 (such as DS275 or MAXIM MAX232 chip)
(3,576 Views)
