how to build bundle information for FFT analysis
Hi guys
I'm trying to read information from NI DAQ one data at a time with an interval of 20ms, which is 50Hz.
I tried to bundle up the information using "bundle" function with the t0 and dt(0.02)
however, FFT keep showing only one peak at 0Hz
am I doing this correct?
(2,973 Views)
That is because the 1 second of data you are feeding doesnt have any frequency components or just a DC.  I tried the same setup as you have and it works fine for sine input.
Post back for queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,932 Views)
Also have the result scaled to db. This will give you a far better overview.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,922 Views)
