how to center a subvi in a sub panel control?
Hi, al
I want to display some subvis in a sub panel of main app. Now, I can insert subvi to sub panel.
But they are not diplaed in the center of sub panel. I want to know whether there is a way to
center my subvi automatically, or I have to adjust by myself.
I also try to disable frame and scroll bars of the sub panel contro, but it don't work. please help
me about it.
thanks.
(4,375 Views)
I didn't try it but open your subVI and go to file -> vi properties -> category = Window Run-Time position, position = centered and save the change.
Ben
(4,373 Views)
I tried it and it didn't work, the vi open in the top left corner of the sub panel. Alternately, what you can do is scale the subVI front panel the same dimension as the sub panel and center what you want in your subVI.
Ben
(4,359 Views)
I tried to find from property node and invoke node to place sub-vi in the center but with no luck. So I think fit or scale panel should be a good workaround
(4,316 Views)
HI, all
thanks all of your help.
(4,295 Views)
