how to change a specific element in array
hi
i have an 1d intialized array
i want to take the existed array and for example add +1 for the 5th element
how can it be done?
thanks
(3,131 Views)
(3,127 Views)
Accepted by therealmask
If you have a newer version of LV, the In Place Element Structure can simplify this.
Lynn
(3,120 Views)
In a typical application you would want to repeat that operation to form a simple histogram. This is most easily achieved by keeping the array in a shift register and repeating the operation in a FOR loop until all data is processed.
My very simple example from a few years ago can be found here. In this case we are counting the number of occurences of small integers in a 1D array. Modify as needed.
(3,105 Views)
