how to change numeric indicator background colour?
hi,
i am acquiring 60 channels of temperature data, that will display on numeric indictor under cluster. user will set the alarm  for temperature level that has to change the back ground color accrodingly.
example: below 60 - Yellow
              above 75- red
how to access these properties under cluster control...?
find attachment
Balaji DP
Message 1 of 13
(8,961 Views)
I think the property node you want is Numeric Text -> Text Colors -> BG Color.
Message 2 of 13
(8,956 Views)
You can use a property node:
You can do something similar to change it to red.
Edit: I red the numbers too fast, so the above image is incorrect. You would simply replace the "greater than" with "less than" and make the numeric 60.
For red, keep the "greater than" and make the numeric 75.
Cory K
Message 3 of 13
(8,952 Views)
yes, i want to change the background colour of nueric text......
Example
find attachment
Balaji DP
Message 4 of 13
(8,948 Views)
Consider using a customized color ramp.
See attachment.
Message 5 of 13
(8,938 Views)
hi,
i am using labview 8.6 version.. can you downgrade your code and send back to me?
Balaji DP
Message 6 of 13
(8,936 Views)
Here is an example for version 8.6
Cory K
Message 7 of 13
(8,933 Views)
nice, thank you....
but how to do this under cluster control...?
find attachment
Balaji DP
Message 8 of 13
(8,926 Views)
You could iterate through the controls using a for loop.
Cory K
Message 9 of 13
(8,912 Views)
no, i could not able to find out this property
Balaji DP
Message 10 of 13
(8,904 Views)
