how to change range in tag configuration editor
i m communicating serial based instrument with labview7.0, when my instrument sends negative values in communication the value 655355 is get displayed.plz can anybody tell me how to display negative values in trends.
Anisha
(2,899 Views)
65535 is a value that can be seen in an unsigned 16 bit integer (U16) which ranges from 0-65535.  It sounds like you want to set yourself up a signed 16 bit integer (I16) which ranges from -32768 to 32767.
Just set your datatype for the value accordingly.
Without seeing any further code, or know what your instrument is, that is the best I can answer.
(2,897 Views)
but my value is -3 ,for -3 value in istrument labview is showing 65535 value.so i want to know how should i set range in labviewdsc so that it will show -3 value.
Anisha
(2,887 Views)
You have to set the datatype to be I16 and not U16.  It's been a long while since I used LV 7.1, and I never used LV 7.0, so I really don't remember where you define that in the tag configuration editor.
(2,869 Views)
can you tell me where that setting is available in tag configuration editor in higher version.Because in L7.0 i have checked all settings but coudnt find these settings in Tag Configuration Editor.
Vijtin
(2,860 Views)
Vijtin
(2,860 Views)
