how to change t delta to relative time
 i have a driver dll that provides me with values of delta t , ie ime between each measurement. How can a change this to so that the delta t adds after each measurement so that i get the relative time instead?
(1,396 Views)
Use a shift register to store time between iterations. You can use Get Data/Time to start with an absolute time or start with a zero value for relative time.
https://tmesystems.net/
(1,383 Views)
but the dt value isn't constant
(1,354 Views)
Accepted by 96RJ
And what is the problem with that? Simply add the values up and output them also as an array!
Rolf Kalbermatter  My Blog
(1,350 Views)
