how to change the background of the waveform chart to a custom background... eg. the oscilloscope screen b/g....
Does anyone know about how to change the background of the waveform chart to a custom background... eg. the oscilloscope screen b/g.... I customized it but it reverts back to empty after a one cycle of the waveform display... Seeking 4 help...
Message 1 of 32
(5,041 Views)
Hi Hussain,
use a GRAPH instead of a CHART and you can embed plot images by property node...
Message 2 of 32
(5,030 Views)
plzz explain in detail sir... i would be grateful to u.... seeking 4 ur reply...thanx
Message 3 of 32
(5,026 Views)
Hi Hussain,
plzz ... u ... 4 ur ... thanx
Could you please use proper English words? It's not my native language and so pretty hard to read when using cumbersome abbrevations...
(Or is this a phenoma related to Facebook?)
Read the help for that property. It's pretty straight-forward to use:
Message 4 of 32
(5,023 Views)
sir how to add the PNG image for the "Draw flattened Pixmap.vi" ..??
Message 6 of 32
(5,013 Views)
Hi Hussain,
as shown by loading it from a PNG file?
Once you have loaded a PNG file to a picture indicator you can also create a picture constant from it to get rid of the PNGLoad function...
Message 7 of 32
(5,010 Views)
and what if i want to change the background of the "waveform chart" instead of "waveform graph"
Message 8 of 32
(5,003 Views)
Hi Hussain,
as said before: only graphs offer the "plot image" properties!
When you insist on using a chart you could make it's background transparent and put it on top of a picture indicator or an image put on the front panel...
Message 9 of 32
(4,995 Views)
yes this will be pretty much useful.... so how to make the background of the chart transparent?
Message 10 of 32
(4,993 Views)
