how to change the background of the waveform chart to a custom background... eg. the oscilloscope screen b/g....
Hi Hussain,
using the "brush" tool from the tools palette?
Message 11 of 32
(1,600 Views)
thank u very much sir, i got i what i was looking for... thanks once again..
Message 12 of 32
(1,597 Views)
i would like to ask one more question sir, just like we increase the intensity of the waveform from the oscilloscope screen... how can we increase the thickness / brightness of the waveform from the waveform chart,,,??
Message 13 of 32
(1,590 Views)
Hi Hussain,
I would take a look at the plot properties of the waveform chart...
Message 14 of 32
(1,589 Views)
but using the properties the would be permanent and not the run time,,, if i want to change the thickness of the waveform while my program is executing...how can i do that...???
Message 15 of 32
(1,586 Views)
but using the properties the change would be permanent and not the run time,,, if i want to change the thickness of the waveform while my program is executing...how can i do that...???
Message 16 of 32
(1,599 Views)
Hi Hussain,
I would still look at the properties of the chart - but this time use a property node on the BD for that purpose...
Message 17 of 32
(1,599 Views)
thank u sir.. i got it...!!
Message 18 of 32
(1,596 Views)
sir, but the plot properties for line width works only for the one current waveform... if i am using multiple waveforms on a single chart and want to increase the width of all of them simultaneously... what should i do...???
Message 19 of 32
(1,593 Views)
Hi Hussain,
first select the "Active Plot", then set it's properties...
Message 20 of 32
(1,582 Views)
