how to change the colour of the point in the x bar chart according to the limits
I wants to change the colour of the points just to classify the points above the control limit ,with in the limit and below the limit .Is it possible in SPC x-bar chart?
kavi
Message 1 of 16
(4,626 Views)
dear friends,
help me where it is possible or not
kavi
Message 2 of 16
(4,624 Views)
Is the SPC of NI's or any other third party's?
Post a snapshot of the graph, or the VI itself will be more useful to understand your exact problem.
- Partha ( CLD until Oct 2027 🙂 )
Message 3 of 16
(4,606 Views)
Hi Karpaga,
I hope you are well. I ask the same question that parthabe, has asked. Is the SPC of NI's or third party? If you are using a built in chart in LabVIEW, then property nodes would solve your issue.
Please have a look at my screenshot, for an example of using property node's to set the colour of the points, depending on the limits.
Hope this helps.
Ashish Naik
Automotive Business Development Manager
National Instruments UK
Message 4 of 16
(4,600 Views)
Im using NI SPC in dsc module i attached the program and screen shots
kavi
Message 5 of 16
(4,592 Views)
Did you try Ashih's suggestion?
Message 6 of 16
(4,583 Views)
I tried but it not works here.another thing ashish suggesstion is slightly vary from wat i need.i want  3 plot colours one for above the limits one for below the limits and one for with in the limits.
kavi
Message 7 of 16
(4,576 Views)
i attached the program in which i include ashish's suggestion
kavi
Message 8 of 16
(4,571 Views)
Use the In Range? function from the Numeric pallette for changing the color of the plot within the limits.
Message Edited by parthabe on 10-20-2009 04:49 AM
Message 9 of 16
(4,566 Views)
Partha thats not the major issue i just for example i put that numeric fn.here i attached the program see the plot point colour is not at all changing.if u can check the program run it and check .
kavi
Message 10 of 16
(4,586 Views)
