how to change the colour of the point in the x bar chart according to the limits
ashish its not working in spc
kavi
Message 11 of 16
(1,133 Views)
Karpaga,
Looking at your vi, and the SPC chart, I have been having a quick experiment and a play around with LabVIEW. You can change, the colour of the UCL, CL and LCL and Points lines, by changing the ActivePlot, using a property node.
To change the line colour, you use the Plot color property node.
To change the colour of the point, use the Plot.Fill/PtColor property node.
A couple of notes, you have wired an iteration count of 1 into your for loop. This means the loop will only iterate once. However you are wanting it to iterate on a point by point basis.
I have modified this, and the colours(as I was debugging in hot, cold, normal colours), and if you watch the code on highlight execution, you will see it changes the point colour, however, I (at this point), think of a way of allowing each point to have a different colour.
Hope this may help.
Ashish Naik
Automotive Business Development Manager
National Instruments UK
Message 12 of 16
(1,112 Views)
thanku for ur valuable reply ashish.my mistake is i forget about the active plot.k..
i come to know now that u clearly understand wat i need i.e different colours for each point according to their classification..
im also trying for that pls try for that and reply me back
kavi
Message 13 of 16
(1,110 Views)
Hi Karpaga,
Sorry I mistyped in my post above. I cannot think of a method (unless you split the waveform into different graphs) of changing each specific point colour in turn.
Sorry! Could you not workaround this, by having a boolean output to say if the limits have been exceeded or not?
If you do manage to solve this (or someone else), I would love to see a solution!
Ashish Naik
Message 14 of 16
(1,105 Views)
k ashish thanku for the support u given..let see..
kavi
Message 15 of 16
(1,098 Views)
Ashish N wrote:
Hi Karpaga,
Please have a look here. Smiley Happy
The solution may be something similar to this. Additional plots may be needed to accomplish this task.
Message Edited by parthabe on 10-20-2009 07:05 AM
- Partha ( CLD until Oct 2027 🙂 )
Message 16 of 16
(1,093 Views)
