how to change the text size of a multicolumn listbox ?
I would like to have all text in my multicolumn listbox biger and bold. I don't find anything with property node.
(3,377 Views)
Hi
Use the Positioning tool to select the entire Multicolumn Listbox. Then use the Text Settings in the LabVIEW toolbar to change the font, style and so on. You will see that the font of all the items in your Multicolumn Listbox (including its label) are changed at once.
If you want to change only one item, than you can use the Text tool.
Luca P.
Application Engineer
Luca
(3,377 Views)
thanks !
so easy.... nd i didn't know this tool....
(3,377 Views)
