how to change value of array element using property node
hello all : )
im using an array of combo-box. the size of array is not fixed.
i want to use the strings[ ] property of combo-box to enter selection texts but since i have placed it inside the array im unable to use this property.
i used 'arrayelem' reference property and connected property node to it but didnt got strings [ ] in the selection.
so is there any way i can use the strings [ ] property
Message 1 of 12
(7,699 Views)
Is this helps?
Message 2 of 12
(7,681 Views)
no this wont help
according to ur method i can only pass a string value to the combo box(similar to enum selection)
i want to pass an array  of strings to strings [ ] property of combo box so that user can have a list of selection
but thanx for trying Smiley Happy
Message 3 of 12
(7,669 Views)
hmm, i see 🙂
I think it is not possible to have elements in an array with different properties. So you cannot have different strings[] property for different elements in the array.
But lets wait for a pro programmer for posting, we will see 🙂
Message 4 of 12
(7,665 Views)
my problem doesnt requires different properties for arrray element i have attached an image file. please refer it. as can be seen in the image file each combo-box has same selections
Message 5 of 12
(7,635 Views)
For that you can just us my vi, with an additional for loop.
Message 6 of 12
(7,630 Views)
ok can u tell me what is 'array 2' in ur vi ??
if im not wrong than its reference of the 'array'
but if it is true then it shouldnt have different name
grrrr... can u post ur vi Smiley Surprised
Message 7 of 12
(7,616 Views)
Array 2 is the reference to the Array.
The problem is Blokk used the built-in VI snippet to create that, which doesn't handle references very well.  The Code Capture Tool is a much better method to create snippets.  In his original code, those two property nodes were implicitly pointing to the Array control.  The LV VI snippet tool breaks those references.
Message 8 of 12
(7,604 Views)
the picture what I posted is a snippet. It is a png file which also contains a vi:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PkCAI&l=en-US
I have found this post. I am just reading it:
http://forums.ni.com/t5/LabVIEW/combobox-in-array-why-does-it-work-this-way/m-p/2146916/highlight/tr...
It might help...
hmm, it is more complicated as I thought :))
edit: just to be CLEAR: so you want to create a new selection LIST for each of the array elements (comboboxes)) OR you just want to set all the comboboxes to a particular value which is ALREADY in the combobox list??
Message 9 of 12
(7,599 Views)
i tried blokks vi using for loop
it simply refreshed/replaced the last added string
but i want to enter same selections (array of strings) in each combo-box
Message 10 of 12
(7,587 Views)
