if statement/case structure motor control
I'm using numerical values from an excel spreadsheet to go through an if statement/case structure and then depending on the numerical value, change the direction of the motor (see attatched file).
The if statement is basically:
IF  Data Value = 1, Motor motion stays the same
IF Data Value > 1 , Change Direction
IF Data Value <1 , Change Direction
The Data Values will be read from an excel file as inputs to the case structure
I want the if statement or case structure to operate as mentioned above but Im not having any luck through my attempts.. Any help or advice would be appreciated!
(2,882 Views)
