how to choose color marker in intensity plot
Hi There,
I am trying to plot my 2D data file in intensity plot. I want to that color plot should be like Red as maximum value while Green as minimum and 0 value should be yellow. I looked at this example http://digital.ni.com/public.nsf/allkb/1ADFF221E27F5B5886256E6F007C7B58?OpenDocument , but in this example they are deciding marker beforehand. In my file i want to choose marker based on maxima and minima value.
Yogesh
Message 1 of 14
(5,065 Views)
Well, you can use "array min/max" on your data and built the Z-scale.marker.values cluster array based on the results. It does not need to be a diagram constant. Let me know if you need help with that.
Message Edited by altenbach on 05-31-2009 12:07 PM
Message 2 of 14
(5,062 Views)
i tried this method and i do not know what is wrong but this one is not working. Also i want maxima and minima to defined by red and green (actually i am using 90% of maxima and minima to be this color and any value higher or lower then that as black color). But i want zero value to be yellow color.
Yogesh
Message 3 of 14
(5,057 Views)
How about something like this?
Message Edited by altenbach on 05-31-2009 12:18 PM
Message 4 of 14
(5,056 Views)
It might be a stupid question but how do you make that array with color box in it?
Message 5 of 14
(5,053 Views)
Sorry, I dod not see your post. Of course you can just multiply the limits by 0.9. Of course you should also reasonable handle cases where them min is larger than zero, for example What is zero is not between max and min?
Anyway, you certainly have way too much code. Why are you reshaping a three-element 1D array to same??
Then don't calculate the average between max and min, just use a zero diagram constant for the middle element as in my example.
Message 6 of 14
(5,052 Views)
Get to the array palette and drop an empty array container on the diagram. Then go to the "graphics & sound...picture functions" palette and drop a color box constant in the array container. Resize to three elements and set the color of each. 😄
Message 7 of 14
(5,050 Views)
I tried your method but somehow marker color is not changing. Do i have to change anything on intensity plot so that it should take marker value from property node.
Yogesh
Message 8 of 14
(5,046 Views)
Can you attach a simplified version of your VI?
Message 9 of 14
(5,044 Views)
Accepted by Yogesh9ic
Here's a simple example. I did not change anything execpt to show the z-scale markers with 1 decimal digit (default is zero). This is just cosmetic.
Message Edited by altenbach on 05-31-2009 12:50 PM
Message 10 of 14
(5,040 Views)
