how to close main program automaticaly
Hi everyone,
After i run the main program, how can the program close itself automaticaly?
Message 1 of 11
(3,410 Views)
This.
Norbert
Norbert
Expert: Geometry
Message 2 of 11
(3,409 Views)
Closing application or want to quit?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 11
(3,390 Views)
when i open and run the labview, i will select one application so, a subvi will be open. Later, the first page must be close itself automaticaly, and the subvi must be continue to run.
Message 4 of 11
(3,373 Views)
Something of this sort... (check attached code, after downloading both VIs, run Splash Screen.vi)
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 5 of 11
(3,359 Views)
Can you upload in 2011..Want to look at it
--Ranjeet
Message 6 of 11
(3,330 Views)
Invoke node -> close front panel.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 11
(3,318 Views)
but that will close the subVI only not the main VI. may be by using reference of that VI
--Ranjeet
Message 8 of 11
(3,307 Views)
The node should be in the main vi, assuming the main program isn't locked by calling the sub-vi. If so, you'll need to set up a Asynchronous call or vi server to start the sub-vi.
/Y
Qestit Systems
Message 9 of 11
(3,300 Views)
then it can be
--Ranjeet
Message 10 of 11
(3,295 Views)
