how to cluster different data types by index?
hi
i have a cluster which contains unknown number of elements of different types( string, array of string, double, array of double),
what i want to do is to get the elements of the cluster one by one find their type and then do further operations on them depending on their type using a case structure
please respond i am new to labview
thank you
(2,400 Views)
Take a look at Queue Control Reference Info.vi that is shipped with labview. Goto Help -> Find Examples and type cluster into the search tab. If you do that you should see it listed.
Hopefully you will find it interesting.
David
(2,396 Views)
