how to cnovert an array of decimal numbers to a hexa decimal number
if i have a numbers like 163, 150,143 like this a three numbers how can I join them and form  a hexa decimal number. please kindly reply
Message 1 of 10
(4,312 Views)
Hi perupadapu,
please explain "join" in this context. What is your expected result for the numbers given ($A3, $96, $8F)?
There's a function "Number To Hex String" in the string->conversion palette...
Message 2 of 10
(4,304 Views)
It's not clear to me how you convert the decimal into hex. Can you be more precise?
Here's my guess in the dark:
Message 3 of 10
(4,302 Views)
not like this. In my motor  encoder the encoder will give the position as three decimal numbers of byte length one. so if it gives 150 , 160, 170. Then how can I get the original decimal number which it meant through these numbers. Please kindly help me.
Message 4 of 10
(4,272 Views)
Hi perumpadapu,
do you read the answers on your question at all?
I repeat my question from message #2:
Message 5 of 10
(4,259 Views)
i need it as a single number not like parts with commas as a single 64 bit decimal. Yoo understand I think
Message 6 of 10
(4,251 Views)
Hi perumpadapu,
do you need your number as "163150143" ("single number not like parts with comma") or (as demonstrated above) as "10720911" after joining the bytes?
Nope, you still doesn't give the expected result!
Again: WHAT IS THE EXPECTED RESULT?
Message 7 of 10
(4,244 Views)
Hi!
The example I provided does exactly what you need, then.
it joins 3  single byte numbers into a 32 bits integer (adding a 0 high byte).
The join order may be wrong but can easily be fixed....
Marco
Message 8 of 10
(4,243 Views)
I need
as like this
0
195
50
hexa decimal numbers corresponds to 50,000  the decimal number.
I need such a conversion. How we can do it
can you please reply
Message 9 of 10
(4,234 Views)
Hi perumpadapu,
as has been shown to you by Marco you should try JoinNumbers for that task:
Your given numbers result in 49970, just a little bit off from your 50000. When there are different conversion rules you have to study your manual...
Message 10 of 10
(4,231 Views)
