how to communicate with DT 9814
Aha,
So how do I go about doing that. Sorry to be a pain.
Message 11 of 14
(698 Views)
George,
When the VI fails to load you should be able to ignore/load anyways.  Once this happens you will see a broken connection to the dll on the block diagram you should be able to check the reference location by opening the dll dialog box.
Greg H.
Message 12 of 14
(697 Views)
Thanks Greg for all your help.
I contacted Data translation help desk. Hope they can figure it out.
Also Measurement and Automation is not seeing the DT9814. I believe I need some Labview  software.
I have NI 288.2 2.71
But if I go to the hardware manager it is tagged as a VISA-DT9814.
I used the Driver wizard.
Message 13 of 14
(689 Views)
Try using the VISA drivers.
http://www.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:3.25.123.1640,ssna...
Greg H.
Message 14 of 14
(687 Views)
