how to compare a given string with a string read from the execution
I need to compare a string read output with a existing string . can you advice a way to it.
(2,652 Views)
Use the equal function to check if the strings are equal Smiley Happy
If that's not what you need you might want to provide some more information about what you want to achieve.
(2,642 Views)
thank you for your reply. I want to see as true or false when the string matches or not matches with the given string. if you provide a Vi with it for this it's very helpful to me.I 'am using Labview 2011 version. so that, that indicator have to be given to case loop selection terminal for executing true and false cases . This is my intention
(2,632 Views)
Something like that?
You can also wire the string directly to the case structure selector terminal and use the comparison string as case selectors.
(2,629 Views)
