10-08-2012 05:45 AM
I need to compare a string read output with a existing string . can you advice a way to it.
10-08-2012 06:13 AM
Use the equal function to check if the strings are equal ![]()
If that's not what you need you might want to provide some more information about what you want to achieve.
10-08-2012 06:54 AM
thank you for your reply. I want to see as true or false when the string matches or not matches with the given string. if you provide a Vi with it for this it's very helpful to me.I 'am using Labview 2011 version. so that, that indicator have to be given to case loop selection terminal for executing true and false cases . This is my intention
10-08-2012 07:01 AM
Something like that?
You can also wire the string directly to the case structure selector terminal and use the comparison string as case selectors.
