how to connect AD595 thermocouple amplifier?
Accepted by topic author jex
Hi Wallice:
Do u have a data sheet about AD595? read the data sheet, it will mention that it has 10mV/degree C. So just put a multiplier so that it can be convert 1V=1C.
Message 31 of 43
(3,649 Views)
Hi.I have problem with ad595 too.i have a K type thermocouple.when i connect it to ad594(i know its for j)it kind of work.but when i connect ad595 to power +5v the alarm turns on.even when i connect pin 1 and 14 together.what is the problem
Message 32 of 43
(3,321 Views)
Dear Arash
There is a diagram there about how exactly to connect but seems you already saw that, the AD595 produces linear analog signal of 10mV/C this acquiring 5 volts means you need 500 C minimum read by the thermocouple ( I am assuming K type) .
please elaborate more the configuration you need to be able to help you.
thanks for your time
Message 33 of 43
(3,306 Views)
Dear Arash
please review this diagram and make sure this is how you connect.
thanks
Message 34 of 43
(3,302 Views)
yes my digram is like that.like i said when i change it to ad594 ,it works so the wiering should not be the problem(594 and 595 are pin compatible).another thing,can we use ad594 for k type without recalibrating in hardware and only change a factor in digital number?
Message 35 of 43
(3,291 Views)
hi howdy,
  i have connected my ic and thermo couple as you suggested. and i am measuring voltage signal through NI daq card. i am gettting good result for temprature greature than 35 degree centi. but when temprature goes below 35 . my ic is giving constant 350 milivolt signal it does not go below. means am able to measure only minimum temp 35 degree. my roop temp is 20 degree . and one more thing should we sort pin 8 and 9 or not. if not than what to do with pin 9.
thank you
punit kumar
iit bombay
Message 36 of 43
(2,464 Views)
Iam facing a problem with AD 595. The output of AD 595 is connected to a digital indicator which shows the the output in millivolts.  Iam using K type thermocouple( chromel-alumel). As the temperature of the thermocouple junction increases beyond 200 degree celcius the output of AD 595 stops at 2078 mV.  For Further increase in temperature there is no raise in output...The output remains the same for higher temperaures.... IC pin connections are as follows, pin 1-chromel (directly connected to the pin), pin-14 alumel (directly connected to the pin), pin-1,13,4 ground, pin 11-+12VCC,pin 7- -12VCC, pin 8 & 9 interconnected and output is measured between this interconnection and ground. at room temperature of around 26 degree celcius the output of AD 595 is 266mV.
Plz help...
Message 37 of 43
(2,256 Views)
Plz help...
Message 38 of 43
(2,244 Views)
Hi shrutimv,
I would recommend you to create a new post for your problem.
Anyway, what DAQ hardware are you using to acquire voltage signal? And what is your maximum and minimum value setting and other DAQ settings for your DAQ in LabVIEW (I presume you're using LabVIEW)?
-Ee Lim-
See that button on the left side of this post...
If you feel my post is helpful, all you need is just (at most) 2 seconds to click that button, to show your appreciation. Thank you~~
Message 39 of 43
(2,238 Views)
iam not using any DAQ hardware...iam just using a digital indicator(does the job of multimeter to display voltage in mV).  It shows maximum of 2078mV though the temperature is raised upto 400 degree celcius.  i thought it cud b the problem of supply voltage to the IC which was 5 volts before and hence changed to 15volts...in spite of which i get the same voltage
Message 40 of 43
(2,219 Views)
