how to connect AD595 thermocouple amplifier?
If you are using any DAQ hardware, how are you getting the reading to a digital indicator. You were asked if you were using LabVIEW. If you aren't, why post here.
Message 41 of 43
(710 Views)
Dear sir,
please check the diagram attached to my earlier post , it worked perfectly between a k-type thermocouple and NI ac. card. however I must say the temp. range in my application didnt exceed 200 .
thanks
Message 42 of 43
(696 Views)
It sounds as though you may be using a digital panel meter, which is essentially a voltmeter. Many of those have a 2 V range so 2078 mV seems quite reasonalble as the maximum possible value which your device can display.  Check the specifications for your device.
Lynn
Message 43 of 43
(687 Views)
