how to connect a Bruel & Kjaer accelerometer to CB-68LP which has only one terminal for connection?Hence the accelerometer cannot be grounded.This is urgent.Please help.
I am using RT series board, PCI-7030/6040E with CB-68LP connectors
(3,314 Views)
Hello;
The accellerometer must be referenced to some gnd line, otherwise it can't give a valid voltage.
The first step is to identify that reference line. Once you have that, connect the accelerometer signal line to the ch+ input of the CB-68LP and the reference line to the ch- of it. Also, place a BIAS resistor in between ch- and AIGND.
Hope this helps.
Filipe A.
Applications Engineer
(3,314 Views)
is the reference line a wire connected to external ground and not the AO ground?the acclerometer has only 1 input line to be connected the ch+ of the CB68-LP
(3,314 Views)
"sorry is the reference line a wire connected to external ground and not the AI ground?the acclerometer has only 1 input line to be connected the ch+ of the
CB68-LP". where is the reference line of the accelerometer?
(3,314 Views)
