07-20-2008 05:04 AM
07-21-2008 07:25 AM - edited 07-21-2008 07:27 AM
First disconnect them and make sure, each one works correctly. If i understand correctly it will be easy to test it manually.
Make sure the Port of USB-6008 is an output and the Port of PIC is set as input.
It is trivial. You should not have any problems
Also they need common ground.
And check that voltage does not go higher than PIC can handle
07-21-2008 10:26 PM
