how to control the bit duration
if i have for example binarystream 01001
and i want to represent the 1's by a duration for example 12 us each
and the 0's by 2us each
i want to be able to control the bit duration..is there anyway to do so ?
(3,083 Views)
Yes it is possible, one alternative is with FPGA's, which type of hardware do you have?
(3,063 Views)
i am not sure of exactly what you mean but i will try to introduce the problem
i am trying to send a bitstream where the 0's and 1's are as shown
and Tari is a value varying from 6.25us to 25 us
(3,037 Views)
The question is where are these bits actually being generated?  You need some sort of digital I/O channel to output this data on a wire.  A serial port would not be capable of doing this.
(3,028 Views)
USRP
i am pretty new at labview..and i am trying to use it to programm an RFID reader transmission
and i have a task now to generate random bits and use the PIE scheme above to display on a graph
and be able to control the time interval of the bits
i hope i am more clear now
(3,022 Views)
I'm not familiar with USRP.  But there is a forum dedicated to it.  You might find help there more quickly.
USRP Software Radio
(3,006 Views)
