how to control the index of the array
im having a 2D 100 x 100 array which i want place a value in some  X x Y place.
Any suggestions ..?
-Jagan
Message 1 of 13
(4,059 Views)
Replace Array Subset.
Message 2 of 13
(4,058 Views)
thanks buddy,
The array im using having the row limitation of 4096 and coloumn of 17000 and each cell having the limitation of 32bit value. But every time this much size is not required. how to create memory dynamically for this array.
Or any other option is there in labview.
Message 3 of 13
(4,041 Views)
Hi jag,
an array of ~265MB should be ok for LabView on modern PCs... (as long as you don't create data copies!)
Either you create an array that big or you don't. Or you have to work on smaller arrays...
Message 4 of 13
(4,037 Views)
In visual C++ there is an option like grid (which makes the array grow snd shrink dynamically)
Is there any option or tool available here?
Message 5 of 13
(4,030 Views)
Hi jag,
you can use "build array" to "grow" an array and "array subset" to "shrink" it. But both function (may) produce data copies...
Message 6 of 13
(4,027 Views)
hi GredW,
do you mean data copy is, using a local variable of that array to store the values or what exactly data copy is??
-Jagan
Message 7 of 13
(4,015 Views)
Hi Jagan,
no, not "local variables".
LabView has to create data copies in memory for certain operations. You can recognize this by using menu entry Tools->Advanced->Show Buffer Allocations (LV7.1, may be different menu entry in LV8+)...
Let's take a typical "build array" operation: You wire a source array and a new element to append to this function. LabView has to create a copy of the source array in a bigger memory space to allow appending of the new element, hence "data copy"/buffer allocation...
Message 8 of 13
(3,999 Views)
Hi GredW
Im using lots of local variable, so it may cause the slower exection of my application isn't it? Ok
Im using LabVIEW 7.0 Express, in that how to see that data copies created?
Message 9 of 13
(3,952 Views)
Hi Jag,
using "lots of locals" is considered bad programming style usually Smiley Wink
You should find that "show buffer allocations" in the same place in LV7. I'm not sure, but maybe it's not included in base versions...
Message 10 of 13
(3,941 Views)
