how to control the index of the array
Hi Gred,
In case of front panel, if i opened more than one panel, im not able to control things on another panel which is in back ground. so how to access the front panel ojects in both the panel? if more than one panel in open state.
And as i said im using one 2 D array with size. that arrya will be in back end which is connected with a table to show data in front panel.
Is that any other way of controlling table from the back end? The user will update the table before configuration of that panel.
I think this array makes the application very slow. how to solve this? Any suggestion???
-Jagan
Message 11 of 13
(758 Views)
Hi Jagan,
Can u upload your vi,so it will be easy to Understand and suggest.
Rgds,
Venky.
Message 12 of 13
(750 Views)
Venkatesh,
shortly i will upload the code.
Message 13 of 13
(708 Views)
