how to convert voltage form analog input of daq to True and false (0=fasle 0.1-10 = true)
i want to use for on LED or Picture
Ex reciece 10 V from ai0 for show LED or Picture on front panel
Help me please
(2,981 Views)
Hi
Is it  what you want to do:
show True value on the boolean when you receive any data in the range 0.1 to 10V?
show False value on the boolean when you receive 0V?
What is the device you are reading from? what is the data type you are reading? is it a single integer value/array of data or waveform data?
what is the rate at which you are sampling the data? how many samples are you reading at a time and how often are you reading it?
post a code if you have started with one.
did you try the comparison function 'equal to 0' or 'not equal to 0'?
Regards
Freelance_LV
TestAutomation Consultant
(2,974 Views)
Accepted by topic author KKSS
As for the comparision part, it should look like this.
As Freelance LV  quoted earlier,you should provide additional info to get apt solution
(2,972 Views)
that is iwant to do but i don know how to pull input form daq
(2,962 Views)
mydaq is 6122 ai0.x
voltage single integer
sample 1k
read 100
(2,960 Views)
Can you please post your vi ?
(2,956 Views)
