‎03-07-2007 07:08 AM
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
‎03-07-2007 08:17 AM
‎03-13-2007 03:21 AM
I already know the things explained in the link givenby you, but i want to do things with .exe files
i would appreciate if anybody can do some guesswork for me to solve the problems, then based on those ideas i can do some experimentaion
can i write a exe file which can read itself as binary file?
what will happen if i just append some data to the exe file?
Tushar Jambhekar
‎03-13-2007 05:10 PM
Hello Tushar,
I'm not sure I fully understand the problem. Why can't you just make a very simple exe that simply launches your custom program? In other words, your exe would simply launch your own application (whether it's LabVIEW or not) and then close itself. The user would not even know that your program is being launched. All that the user would see is when they double click the exe your program would open.
If you just start appending data to an exe file, you will corrupt the exe and it will no longer run. I am about 99.9% sure you cannot re-define how an exe is launched in Windows.
Justin D
‎03-14-2007 12:39 AM
Tushar Jambhekar
‎03-15-2007 10:22 AM
