how to create a controlled moving object on screen
I wanted to control the part of the picture element for movement of a picture element on the screen, visibility of the picture element assaigning timeing factor and so on for my automaton project
Message 1 of 20
(4,874 Views)
Look in the LabVIEW/Example/Picture folder on your hard disk. There is a shipping robot.vi that demonstrate all you need to learn.
There is something equivalent (Robot arm.vi) in 3D. Download the free 3D picture toolkit from here
Hope this helps.
CC
Chilly Charly    (aka CC)
Message 2 of 20
(4,860 Views)
thanks cc for your help but
I am running the labview software with version 7.0 which is not supported by your program, it asks for v 7.1 and higher version, the first example that was quoted was helpful but it is required to be developed using some natural picture images like BMP, can someone help.
thanks to all
jagadeesh raju
Message 3 of 20
(4,796 Views)
@jagadeesh wrote:
The first example that was quoted was helpful but it is required to be developed using some natural picture images like BMP, can someone help.
thanks to all
jagadeesh raju
a "Natural" picture image can be read from file with the "Read bitmap file" function (in the "Graphic & sound>Graphic formats" subpalette). Then, the image can be displayed with the "Draw flattened pixmap" function (in the "Graphic & Sound>Picture functions" subpalette).
CC
Message 4 of 20
(4,790 Views)
Thanks for your sugestion CC,
The main obstacle that i am facing is that after getting the BMP onto my front panel I wanted to move a particular section of the BMP, to make it as a real time scenario,is it possible?
or with a second option in hand, importing each BMP of a cabinet piece by piece and making it to move on screen?
if it is possible to move each bmp on screen how can I do that?
which one would be the best option that I can opt for?
thanks again
jagadeesh raju
Message 5 of 20
(4,787 Views)
thanks again
jagadeesh raju
I think the second option is the easiest, since you can recompose the final image from the different pieces, disposed where you want. Use an image editing software to remove unwanted parts of the pict that will be moved. Try it !
CC
Message 6 of 20
(4,785 Views)
Hi CC,
I didn't get your suggestion exactly.
1.which is the software that you have suggested to edit the BMP?
2.is it possible to load different forms of cabinet by this procedure?
3.is their any option in labview to edit or remove the unwanted picture?
4.examples regarding my problem would be of great help!!!!!
Message 7 of 20
(4,785 Views)
You can use Photoshop or any other image editing software to optimize your image fragments.
If you give me your mail adress, I'll send you an example (I can't post attachments of more than 26 ko...)
CC
Message 8 of 20
(4,774 Views)
thanks for your concerned response,
my mail Id is
cjagadeeshraju@yahoo.co.in,
forward the example to the above Id
thanks
jagadeesh
Message 9 of 20
(4,776 Views)
Thanks CC,
I made the picture on the screen to move, I wanted to get the help from your proram but it was confined to 7.1 version and I am running the LabVIEW on 7.0,
Now I am facing a problem with VISA, I want to loop back the same COM port, that is transmitting and receiving in the same port.
I tried to configure the COM port but it returned error at the property node.even I couldn't open the VISA.
can someone help me,
raju
Message 10 of 20
(4,756 Views)
