how to create a pause botton to pause a programme
I would like to create pause button to pause the process.
Then a Run button that when pressed will continue from where it last stopped at. .
Attached is my programme. .
I would really like your help. .
Thank you. .
oh and the while loop outside the stacked sequence structure is so that my programme will run when the start button on the front panel is pressed. .
Message 1 of 14
(5,257 Views)
Accepted by Puchu
One simple approach would be to put the code in your While loop into the False case of a Case structure.  Wire a "Pause" boolean control to the case selector and set its On text to "Resume".  Put a small delay in the True case to prevent it from hogging the CPU during a pause and Bob will be your uncle.
Edit - make sure to set the mechanical action of the Pause boolean to Switch When Pressed/Released.
Jim
Message 2 of 14
(5,238 Views)
hi!
May I know what you mean by "set its On text to "Resume""?
Sorry I'm new to LabVIEW. .
Message 3 of 14
(5,213 Views)
Change the text that shows up on the boolean button.  Go to the properties dialog for that button.
Message 4 of 14
(5,208 Views)
thanks!
Message 5 of 14
(5,196 Views)
hi. It still does not seem to be working for me. Sorry but could you help me see if I'm missing anything. .
Thanks. .
Message 6 of 14
(5,195 Views)
@jcarmody wrote:
One simple approach would be to put the code in your While loop into the False case of a Case structure [...]
You put the entire While loop into the Case structure; the Case structure belongs inside your loop.
Jim
Message 7 of 14
(5,183 Views)
oh yes!! it's working!! thank you so much! 😄
Message 8 of 14
(5,155 Views)
hi. one more thing. I want to make a button which clears the waveform chart when pressed. . help please. .
Message 9 of 14
(5,138 Views)
Add a case structure containing a property node for the chart history (right-click...create...property node...chart history)  and wire an empty array to it (right-click...create...constant). Wire a latch action button to the boolean selector of the case structure. Place the case structure in parallel to the existing case structure so you can clear the chart independently of the main case state.
A few more points.
  • You outer sequence frame is not needed. Simply wire from the first loop to the second loop boundary to create a data depedency.
  • Even better, eliminate the first loop and instead start the main loop in the pause mode. No start button needed. (Add more functionalty, and soon you have a state machine.)
  • Your "Equal FALSE" construct is clumsy. a simple "invert" will to the same.
  • You have a lot of duplicate code. It might be easier to operate on arrays instead.
  • Why do you need four identical diagram constants for all three conditions. One each is enough. Don't be afraid to branch a wire.
  • Coloring diagram constant will not color the string indicator wired to it. You need to change the propertied of the indicator.
Message 10 of 14
(5,131 Views)
